That's the stuff. Best thing for cleaning out an oil-contaminated cooling system. And don't shirk on how much you put in there, a pound or so at least. Even then you may not get it all at the first go-round. It's also important to rinse every last trace of the detergent out of the system when the cleaning process is completed.if you don't like a lot of bubbles, try cascade dishwasher detergent.
The people who make those environmental decisions don't work either. Just say'n.
Don’t make the mistake I made many years ago flushing out the rad on a 68A D8 after a tranny cooler cracked.
I used my mother’s baking powder rather than baking soda to clean the rad!!!!!!
You may or may not have a high horse engine depending on if only the block has been changed during a previous rebuild. Check the turbo and air cleaner arrangements to see if they match a high horse application. On those old machines a lot of parts may have been changed over its life. As far as i know you can still have a low horse engine with a high horse turbo and air cleaner. Maybe someone else will chime in
Commercial blue dawn soap will out clean everything short of just putting purple power in the rad.
With the plate you have the 1/4 hole gets a cork.
the 1/8 hole next to the hose should be the gauge line.
Bob
