D6t electrical
watglen
Dunnville, Ontario, Canada
Hello everyone
I need to locate a good spot to pull 12v power for a fm radio.
It needs to turn off with the ignition.
Where would i find that?
Thx
Check behind the cab linings. There should be one hardwired into the machine harness next to the Implement ECM and a 2nd one with a plug & play accessory connector CONN 45 mounted next to the Powertrain ECM.
If the 2nd converter is not on your machine a Cat 340-7161 is plug & play to that 6-pin connector on the machine harness. Both wires marked in Blue on CONN 45 are switched from the ignition key.
