Machine #D6R #5LN02787
I am needing to replace the equalizer bar end bearings and seals and am wondering if it can be done without removing the bar from the machine? I know that the manual says remove the track frame but it sure looks like it would come out without track frame removal. I have the bearings, seals and new snap rings along with the center bushing and seals on hand if I need them also
Any tips and tricks would be appreciated. I am getting some good heavy blocks to crib up the nose in the morning.
Also what are my options if the bearing bore is damaged when I get it apart?
