D6h tc issues
D6hmatt
Im not sure machine has 5000hr on it. But i bought at a auction unknow of any history so its anyone gues the machine more likely has 15000 or 25000hr on it lol just a new hr meter maybe
D6hmatt
Welll thats just it. I assume it was changed at a major overhaul like engine or transmission but that might just be my optamism. Doesnt realy matter how many boyfreinds she had before me were married now ..........
John C.
Nige is right about abusing a torque converter. The abuse is mostly in the maintenance. You can overheat it but that is usually a result of a plugged radiator. Not changing the transmission oil is about the only other thing I can think of. Which bearing was going bad?
Overheating will only kill a converter if the cooling system is not up to snuff IMHO. Even then it would take hundreds if not thousands of hours to do it and all it would generally do is cook the seals, not trash the hard parts such as bearings.
HeavyMetalRepair
California
Inexperienced operators can and do overheat torque converters with perfectly functioning cooling systems. Operating in the incorrect speed and stalling the converter for long periods of time. I see it frequently in my area.
We’ll have to agree to disagree then, because IMO repeatedly overheating a converter will cook the seals first & foremost, not trash the mechanical parts. This will certainly shorten the life of the component but generally speaking one shouldn’t need to go into the case with a shovel to dig the broken bits out.
@D6hmatt - We’re still waiting for some photos of the damage from inside the converter.
D6hmatt
Fair enough. Ya i will get pics when i drop off parts at the mechanics shop. Im not sure which bearing went but he described it to me that it looked like it had been rebuilt before and as bearing got more play it allowed stator,rotar and turbine all to contact one and another a bit so suggested we chamge out scored parts as well. It looks basicle like it was just time for a rebuild not realy abuse or overheating more just that many hrs on it since last rebuild which who knows when. But like u guys say it will be fresh now last me long time. Im the only guy who runs it and its basicle my side hustle just a little brushing, dirt work, cleaning up farm land so i never realy see any high oil temps or real hard hard work its all just a little of everything. I only put on maybe 300hr a year so should last me long time. The hottest ive ever seen it run was a dirty hill i was cutting push down and back up it so no good coolimg time but i was 110c on torque converter and 100c on engine. I beleive book says max of 130c on tc operating and that was very short time so moving forward i think this should last me awile.
D6hmatt
What is ur guys opinion on cats aftermarket parts? Like there jobber line. Seem alot more affordable for turbine and stator and such. I plan on going with genuine cat bearings and seals. And ther aftermarket big parts.
Simon C
Heavy Equipment Mechanic
Built a lot of Komatsu torques, was hard to get all the correct parts by serial number breaks from them , never mind from aftermarket, who some of the bearings I seen before were fit for trash bin only. Maybe someone else has found some other better supplier, but if something cheap grenades into the system the OEM parts will look cheap by then.
Simon C
John C.
If the interior bits were rubbing it means the thrust bearings between them or the mounting points for those bearings are damaged and the impeller, turbine and stator should be replaced. My remark on overheating the convertor related to a way to abuse it. I think everyone will agree that overheating a transmission would be considered abuse. I'm surprised that this unit wasn't overheating all the time with that much leakage.
If you have damage to the internal parts of the torque converter it is always recommended by dealers and manufacturers to remove and at least inspect the converter cooler.
D6hmatt
I havent actualy seen the parts yet. The mechanic said it looks like bearing had enough play to take out the seal and slight. Scoring on the others so we will change them also he said there not bad but while weere at it may as well change out. The cat was running fine had been pushing for days and in the snap of a finger flooded tc instatly.
