Jakes dozer
Recently rebuilt the engine in my D5k YYY01385 serial number. We had it running for about 10 minutes and it shut down and will not crank again. Fault codes show high engine temp and low oil pressure and a speed sensor fault. Neither of which are accurate as I watched the oil pressure and it stayed around 50-60. The temp never got up to half way and the infrared heat gun showed around 175-190 degrees. We went ahead and changed all the fuel lines from the filters to pump. Injectors are new and high pressure pump has been changed recently also. UPS dropped the pump so the sensor on top of the pump was changed also. Active fault codes are e360-1 e360-2 e360-3
E361-1 e361-2 e361-3 2688-08 also hand primer bulb has been changed. Doesn’t stay pressured up once you pump on it a few times. It gets hard and then bleeds off and is fairly easy to pump.
Any help is much appreciated. This has me scratching my head. I’ve got a lot
Of money tied up in this dozer and need to get it back on a job asap. It has been down for about 2 years.
