RZucker
30-35 lb ft for 3/8" bolts, tighten them evenly to avoid bending the clamps. The clamps will have a small amount of clearance under them when tightened. That's necessary to keep the hose flange tight to the block.
To bleed the air, fill the reservoir to "Full" and operate the controls several times in both directions to fill the lines and cylinders. Stop and check the oil level immediately if you hear the pump growl, other wise after cycling the controls set every thing on the ground and check the oil level again. Should be good to go after that.
