After all the rain the past few weeks in SE Tn., I finally had a chance to run my new to me D4H for about an hour. After some light pushing of a few small piles of dirt, headed to my pond to push around some piles of silt I need to spread out. Starting noticing light grey smoke coming from the front of the dozer radiator when I put a real heavy load on it. Thought I had an oil leak but as soon as I put it in neutral it started clearing up. No smoke at max throttle, moving around not under load or light load. The best I can tell, the smoke smells like normal diesel exhaust (hard to stop and juup off the dozer and run out in front of it and catch up to the smoke when the wind is blowing, my wife thought I was going crazy or getting chased by yellowjackets). The dozer had sat for several months before I bought it, so I drained the fuel, changed all the filters and fluids, it starts great and runs great as far as I can tell. So, what do I need to look at?
Second question, based on the soot on the motor and the above issue, and not being able to find an exhaust leak, it seems the fan is pulling exhaust fumes back into the engine compartment from the gap where the muffler and hood/stack meet. I can stick my fingers in the gap, so that is about the size all the way around. What can I do to stop exhaust from getting pulled back thru the fan?
Some info to help, it is SN9DB01218, unknown hours with a 3204 engine.
