Gentlmen I am having problem with a D3 B 23Y . I have tried everything I know to check as far as cable and connections. cleaned all and appears to have no voltage drop.
battery checked at 941Cold Crancking at 13.25 Volts
if I put a battery booster on at start position with 225 amp. I can get it to start after few click at the switch.
it had those push button switch with rubber boots. I t came that way.
Can I get some suggestion.:beerchug:beerchug
