D11T youtube video
JDOFMEMI
SoCal
That is a nice looking tractor alright.
As much as I would love to have one, I bet the old D-9L's pushing scrapers there have made the company more money than the new 11 ever will. I doubt it will last as long as the old ones with all the electronics and such.
I saw that ripper frame in the dirt also. If he can sink that thing that deep he shouldn't be ripping at all. The scrapers could load it with a push.
Scrub Puller
Yair . . . carlsharp and John C. I reckon you blokes are a little picky. Dunno how much ripping you have done but that bloke knows his bickies...he knows what the second set of rams are for and he's keeping the cut dressed up neat...even did a roll run to press in and break some guleys...any issues about the main beam dragging are inconsiquential, he's after (and getting) penetration
I have spent far too many nights welding torn out floors to ever say that most dirt won't load better with a rip. Done properly ripping time is seldom wasted whether pushing with the blade or loading scrapers...a fact of life that is often lost on many dirt bosses.
Just watch that video again and even though it is good going you will see that eleven pause a couple of times and the tracks slip...imagine the pressure on a scraper bowl (if that dirt was unripped) with a tyro taking a too deep cut with one of those nines and that big sucker up his arse...just sayin', that's all .
Cheers.
JDOFMEMI
SoCal
As Scrub says, nothing wrong with how he is ripping. The ripper bar is just knocking off the high spots anyway. The deeper he gets now, the more they can load before the next time he rips that same area. And showing the talent to break up the bigger rocks so they don't become tire killers is something it takes a well sesasoned hand to do.
He is using proper tip angle after rolling back to get penetration, and keeping track slip down, not that the conditions are that bad, but good technique makes it look easier than it really is. A nice sized machine helps too.
Yes, you could load it without ripping, but you can load it twice as fast after it is well ripped, and without damage.
I'll go as far as to say if it's stalling a D11 with a ripper then I shudder to imagine the stresses on the draft arms & cutting edges when a D10 rams a 651 up the ar$e if that material wasn't ripped first.
He can't get the ripper frame any deeper which is good and every time he hits a hard patch he's prying it out with the ripper tip cylinders instead of lettin' er rip and spinning the tracks.
He could come and work for me any time.
Radrock
Joplin, Missouri
Heavy equipment operator
I agree with Scrub, JD and Nige, Nothing wrong with the way he is ripping and it is better for the scraper. I run an 8T. Go ahead and laugh. It looks like a tonka toy next to that 11. But ripping techniques are the same. I don't agree with draging the ripper bar in the rocks however. That 11 may be designed a bit different but on my 8 it is open in front of that bar and rocks can be push up onto the frame and the next time you lift the ripper bang,, there goes a hydraulic line or the valve body. Of course you can't always keep em out of the dirt. I ran a single shank ripper once and there were brush guard on the back windows and you couldn't see a darn thing. With mine you can look down and see the center opening and outside shanks all of the time. And then again he is only pulling two shanks and I usually have all three down. That center shank will no doubt pull more rocks up in the center. Some of the scraper operators I have been around think the have to load that bowl up till its running out on all four sides. Have to push then an extra 100 yards just cause the won't pull up and go unload. That's a good reason for me not to be a push cat operator hahaha.. It makes me mad as heck. Good scraper operators are just as important as good dozer operators. How does that song go?? you gotta know when to hold them and you gotta know when to fold them? We'll just have to change the wording a little bit. Every one have a great day!!!:)
Scrub Puller
Yair ...a bit off topic but it looks like there could be a few yards in that cut...an ideal application in that material for slope boards or "batter blades" as we call them here.
The main thing is not to undercut the toe. A good bloke on a slope board would shave those batters back real nice.
Cheers.
Gavin84w
Maybe just a tad to deep but at the end of the day if the ripper bed or table is parallel to the ground which is where he pretty much has it then that is the correct way. This way you get throat clearance for material to not plug the bottom and the stresses are channelled through to the main frame evenly. In the good going he is in and rolling the ripper box around to the right position like he does it is inevitable you will do a bit of bulldozing when you have an MS ripper.
Just remember over ripping is just as bad as under ripping.
hvy 1ton
Lawrence, KS
I was waiting for someone to complain about him backblading...:rolleyes: guess the ripper was too distracting.:lmao
Scrub Puller
Yair...that was a perfect example of where backblading has its place. He is keeping the surface of the cut tidy, consolidated and relitivly smooth.
Despite a lot of comment to the contrary running a scraper spread is not all about full on balls out production...you have to set the job up to minimise down time due to mechanical failure and in particular tyre failure.
To my eyes those objectives are being achieved by the operating methods and the choice of a multi-shank ripper on the machine.
Cheers.
In the mining that I've been part of, if you could bury the ripper to the frame, you get longer shanks. Those frames are soft and pliable to absorb the shock loading that is always part of the process.
I've had rock jammed in the shank pockets so hard we had to jack hammer them loose. I've had broken joints and seen the bottom plates of the ripper frames worn clear through.
I want the wear on the teeth and shank protector, not on the ripper frame.
alco
here
The key to that statement is that the video isn't of mining John. Ripping for scrapers is a different beast than ripping so you can push it with a dozer.
Like it has been said above, that wasn't his first pass over the area. He was working the material a bit more to make sure it was good to go.
RDG
Qld Australia
Multi skilled plant operator for 40+yrs
Nice looking dozer, good to see they havent added all the junk on it to restrict visibility like they do in the mines over here. Cheers RDG.
Iowa
IMO, not being experienced in ripping, those conditions in the You Tube, or on machine ANYWHERE the size of the 11T, I would probably lower the 'dozer until the tips of the corner bits were just clearing the ground to more nearly balance the machine when ripping-that's an extreme draft load and the front of the machine and the front of the tracks do appear to be up. Any comments from those with the experience?
Radrock
Joplin, Missouri
Nope nope nope. He's ripping with his shank in and in very hard ground this will raise the front of your Dozer somewhat. If you lower the Dozer just touching the ground then the second he clears the hard ground and the front drops back down the Dozer blade will dip out some dirt and then you will drive through the ripple which can be rough at times.
Tracklayer
minnesota
What exactly causes that metallic squealing sound when pulling the ripper? I have never heard a sound quite like that coming from a dozer. I assume it is coming from the tracks, but what are the details of its cause?
Tracklayer
minnesota
Is the sound coming from between the sprocket teeth and the bushings, or from between the bushings and the pins?
