GaryHoff
Hi,
I have a cx240, with the cummins engine. I am not satisified with the hydraulic performance of the unit, as it seems to have a hard time even picking its tracks off the ground when digging. The pressures are in spec (5000psi standard and 5400psi power lift). The unit also has a long stick on it. I want to turn up the pressures, and was wondering how high would be ok without risking pump damage? Or has someone ran into this issue before, and had a simple fix?
Thx
Thx
