My snow blower never had this problem before. The engine comes from a 1995 Dodge truck, the P-pump was reused *as was* many years ago when I rebuilt the engine.
Running cold with good oil pressure and slowly rising coolant temperature there is no problem. Once hot it begins to just power down for no apparent reason under load or totally off load. A restart attempt after a minute or two of cursing has always been successful thus far. If I run it to 2200 then isntead of powerdown it may just become erratic between 1800-2200, it may or may not stall down regardless. I find no issues in the fuel system, but I did notice that a pressure gauge placed into the turbo output is all over the place, probably unrelated and the gauge make is unbranded and it never showed much more than 5-8 psi. Besides, at torque speeds the turbo isn't of much effect anyway, it WAS useful in a truck turning 3,000 rpm back in its day. For now I can just limit ops to low power (1400-1600) sticking to the warmup period.
Any suspects? It's winter here and I ain't too keen on getting tools out into the snow but I could try a few leads.
