I haven't been around one of those much at all, but I'll bet you anything that you'll find better advice (either here, or some other online site) than you can expect to get from the Deere tech who you happen to get sent out. If the adjustment is really that demanding, do you really think a kid with a computer is going to have learned it or done it before?
Assuming you're not in a hurry, let the dealer worry about the 2 month old combines sitting with dead computers and wait until somebody comes along who knows old Deere crawlers.
Thanks for your reply. In the "FIRST PICTURE" just above the track is a cover with 3 bolts, I took the cover off and there is a bolt that has something to do with adjusting
the throw out bearing and pressure plate, than there's is a brake band that is wrapped around the pressure plate that also needs to be adjusted, not to mention under the seat is
a linkage which operates a hydraulic power steering cylinder which I believe controls the amount of travel in the steering arm.
My problem is I don't know which is which or how to start the sequence.
When I started this post I was hoping someone may have a 450 b and had to replace the steering brake, clutch, and P.P. and be able to give some insight on how the process works
as well as the price for parts and labor.
The only info. on parts I could find consists of a P.P. throw out bearing , multiple fiber, steel plates and brake band, cost is approx. $700.00, but they all differ somewhat, and you need to have the old parts to reference, also the price is for a "after market kit"
And no I'm not in a hurry, and sure do hope someone who has a 450b could shed some light on this topic.
