Pulled off another set of wheels today in between other work... Go the first 9 nuts off and the last one wouldn't budge!!! sat on it for 20-30 seconds!!! so put two adjacent nuts back on and held em' down for a bit
then went back to the stuck one for another 30 seconds!!! went back n forth a bit was just about to go grab something a bit more serious and tried it once more for 20 seconds and it finally started to move!!!! success
So started pulling the inner wheel off got two studs off and the impact quits...... 9 amp batt which I pulled right off the charger this morning was depleted
so popped in another one and went on about my nut removal process
got to the fourth one and it wouldn't budge... tried a few others got some off but there were four that just wouldn't move... anyways long story short I went through both 9 amp batts just pulling one set of wheels off, I'm not sure who put these on or how much torque they used but the 3/4 milwaukee was a bit under powered on this set!!!
And the hammer area gets hot enough to burn your forearm if you let it hammer away for a while
