joispoi
I pulled the injectors on my truck this morning and sent them off to get rebuilt. While I have them out, I figured I'd test the compression. Using an off the shelf hand-held tester form Napa, I held it to the injector socket while cranking. The residual oil in the cylinder popped, blackening my hand and the gauge. I was a "slightly" surprised.:tong
After cranking it enough to clear the cylinders, the readings I got were all around 125psi. I can't say if the gauge is accurate since I have nothing else to compare it to.
Does anybody know what the compression reading should be on this motor? I believe it's a 16.9:1 compression ratio but not 100% certain.
