Lee Timmons
Hi all,
I have one more question I'd like to ask. I've decided to change all the fluids and filters on my 1989 jd 210c. It says that it holds 8 qts of oil in the trans. When I drained the oil it sure didn't look like 8qts.to me. Does the torque converter still have oil in it when you drain the trans.system? If so how do you make sure you're replacing that òld oil too? Is there some way to get it out? Or maybe you just leave it in? And i checked the dipstick before draining and it showed full. The trans.,torque converter, and reverser are all together right? How about the rearend and wet brakes, where does that oil come from?
thanks for any and all responses, Lee
