Tinkerer
Welcome to HEF, Diggerman1 !
I've seen some dandy's but that one is a trophy, most people have no clue that screen is in there. Good find.Think that's what's left of a screen filter that goes in the top of the fuel bowl attached to the fuel lift pump.
That is what I also thought when I first saw it. But, it must be so dirty it looks solid.Think that's what's left of a screen filter that goes in the top of the fuel bowl attached to the fuel lift pump.
Well, that had to be ONE of the fuel restrictions. After the video of it running with no throttle response. I went to move it the next Saturday and it would not run at all. So I dismantled this area of the fuel system, found this filter beat up and clogged, & just removed it. While I had it apart I hooked a piece of hose to the tank outlet and blew into it just in case there was some settling of sediment around that area. Didn't get much resistance and immediate bubbles heard in the tank.Was “THAT” the fuel restriction.??
How’s it run now.??
What rpm r u mowing.??
Inorder to “fix it” u need to work the snot outta it.. for an hour at least..
Hopefully it’ll burn off the carbon and let things seal..
