todd raymond
How do you remove starter on cat 303cr
We must get you prepared for the task first.How do you remove starter on cat 303cr
My 303cr dma prefix the engine faces the opposite way it is a buggerI used "BXT" prefix, since you didn't provide serial number.View attachment 297624
Idk my dma pre fix Machine the has 303cr on the tag
I sure hope I never have to pull mine apart that bad. I've been close to it buy mines clean so it isn't so bad. Looks a good wash would do this one some good
There appear to be various methods quoted.
Can you provide a machine Serial Number.? That might narrow it down a bit.
Sweet lolHey, just realized!
You can see the starter in that picture.
Well I was to the bottom bolt before I I wrote that thread I'd about take a big bar and break off the starter flange there's no core but my luck I'd break the Block lol and the one video says the bottom bolt is always left out because they are such a bitch that was every one but mine lol I'm going to do everything I can not to take the counter weight, the guard, the radiator , my God are you kidding me!!!and in today's time s why in the hell do they have a bolt with a fkng nut o it.in in the worst possible spot . How many people know the trick for the bitch bolt on a Cummins air compressor ? I took and shortened the bolt and it saves about an hour at least .I think you guys scared him away.
I remember it being an absolute nightmare of a job. Especially the ones with blades. I like how the manual says, "the preferred method" is working from under the machine. Because of course the machine is going to be parked in the one position where that's possible.
The ones I did had to be done through the access hole under the seat. I remember the holes behind the access panels being disappointingly small. You can get to the starter wiring okay. But the starter bolts....
Why do I have to deal with a nut and bolt while working through a hole that I can hardly get one hand through? Lot of money in the swear jar at that point. Now you have to deal with the other bolt that you can't even see.
I think I ended up tying a string to a stubby 14mm gear wrench and lowering down the back of the engine where the starter was.
Nightmare machines to maintain when they make them without cabs that tilt.
I have been taking care of that unit since it was new. So I have probably replaced at least half of those hoses (and the starter about three times) never had to take anything but panels before.I sure hope I never have to pull mine apart that bad. I've been close to it buy mines clean so it isn't so bad. Looks a good wash would do this one some good
Oh yes! Just need to remove another couple of panels and you'll be able to get to itHey, just realized!
