syncropete
Having a problem with a 140H grader. I am sure its a simple fault but I cannot access SIS right now to give me an idea of pressures etc. Its a basic 5HM machine with mechanical pump on 3306. I have run ET and it shows only VHP solenoid as being high current. The machine will select all gears when the wheels are raised in the air (suggesting signal to solenoids is ok) but if you put it back on the ground it will only drive in gears 5678 forward and 456 reverse. In these gears it has plenty of drive and in the non working gears the machine will move very slightly. The oil looks clean. I am not sure how the transmission is configured internally but I am almost certain that somebody will be able to tell by the gears that are working. The valve block has been dismantled before from what I can tell. Any help would be much appreciated as here in Sierra leone I am pretty much alone and being a VOLVO trained fitter is not helping right now. Thanks in advance.
Pete
Pete
