HelloHaving a problem with a 140H grader. I am sure its a simple fault but I cannot access SIS right now to give me an idea of pressures etc. Its a basic 5HM machine with mechanical pump on 3306. I have run ET and it shows only VHP solenoid as being high current. The machine will select all gears when the wheels are raised in the air (suggesting signal to solenoids is ok) but if you put it back on the ground it will only drive in gears 5678 forward and 456 reverse. In these gears it has plenty of drive and in the non working gears the machine will move very slightly. The oil looks clean. I am not sure how the transmission is configured internally but I am almost certain that somebody will be able to tell by the gears that are working. The valve block has been dismantled before from what I can tell. Any help would be much appreciated as here in Sierra leone I am pretty much alone and being a VOLVO trained fitter is not helping right now. Thanks in advance.
Pete
Hello Mr NigeTwo questions: -
1. Which speeds are not working..?
2. Have you removed the transmission suction screen to check for burned clutch material..?
Of course the failure occurred suddenly. Before all the 8 forward speeds and the 6 rearward worked without problems. we already changed the gear leverIs this something that appeared suddenly..?
If I recall correctly the maxmum gear in both forward and reverse in the transmission can be programmed to limit the ground speed. This machine sounds to me as though it has been programmed to not shift above 6th speed forward and 3rd speed reverse. I used to do the same thing to stop grader operators speeding on haul roads.
Do you mean that you removed the transmission and repaired the damaged clutch.?then Ichanged the clutch for the burned ones but the problem is the same.
YesDo you mean that you removed the transmission and repaired the damaged clutch.?
ok sir, I made swaped the harness for proportional solenoids from solenid no.e to solenoid no.1, then the I try to select the no.2 gear on the gear selector lever, now the speed is there but when I try to measure the preasure for no.2 on test port no.2 it is zero, but Igate preasur on test port 1.Ok, I have read your first post again to try to understand it better.
Right now you have no drive in speeds 2, 3, & 6 Forward. Is that correct.?
Please can you describe in detail exactly what you did to change the symptoms from no drive in 2/3/6 Forward to no drive in 1/4/5/7/8 Forward.?
