Entropy1
The problem with my borescope is that I cannot manipulate it. It will hold a general shape when I bend it, then I can only push/pull it. It will not change directions (bend) while being pushed - at least not in a predictable fashion. The probe will snake up (buckle) when being pushed around a tight turn. It works great for inspecting straight sections (pipe, duct, etc). I had trouble feeding it through a 90 degree turn in the exhaust manifold. If I remove the precombustion chamber, it's a straight shot directly into the cylinders.
And for removing the precombustion chambers - the service manual says they're torqued to 200 ft-lbs upon installation. I'm assuming these have never been removed - but who knows? Should I use a breaker-bar, and apply steady torque? Or should I try a small impact gun? My gut tells me to not hit them with an impact. But occasionally an impact is the preferred tool. Any recommendations? I need to make sure my extraction bolt has enough engagement with the splines (when removing the retainer & chamber together - they're supposed to be removed separately. When removing both together, the extraction bolt sits higher above the chamber).
