My set is over 50 years old.If I decide to rebuild the engine (still TBD - depending on whether or not existing castings are freeze-cracked) - I intended to get the head serviced while it's off. This would include my replacing soft-goods on the precombustion chamber retainer, and also the combustion-seal at the bottom of the chamber.
The tool group required is Part No. 5F9217
You most likely never need them again the newer motors use different tools.
If the machine shop has been around awhile they should have a set as the precups come out to work on the head.
Bad Bob
