trkirkendall
I have a 2005 CAT257B. The lift arm cylinders will leak down fast while running the machine. You have to hold back on the joystick to keep it up. If you turn the machine off it does not leak down. I have repacked the cylinders and it still does it.
Also, when the machine warms up it does not want to turn. When you first crank it it turns great. It tracks straight, does not pull to one side. Just put a new radiator/hydraulic cooler on it. & new hydraulic filter. I have owned the machine for 6 years. It has had these issues since I bought it.
S/N - CAT0257BVSLK03751
