CAT IT24F Engine block heater
dzlnut
Cali
I have 1995 CAT IT24F it has a very hard time starting in cold weather. It is below 32 degrees on a regular basis.
I was wondering if I should install an intake heater or would installing an engine block heater be better? or both?
does anyone have installation instructions for the engine block heater and intake heater?
Once I start up the tractor for the day it stays running all day until it gets parked next to a power source
I purchased an engine block heater kit with the element, cord etc The element part # is 124-0687 from CAT
512high
new hampshire
Serial number of machine....
Does that have an intake grid heater? and is it working? That should be plenty if it is mostly above 10F.
Someone will be along with the cat instructions, or look up zerostart and they'll have the directions also. They just copy the oem, will use the same hole, and similar heater. Seems like a 3116 was the middle of the right side, but the 4 might be less access.
dzlnut
Cali
It is not equipped with an intake grid heater, the switch location for it is a blank
that would be great I appreciate the help
An intake Grid heater was an option on all IT24F machines of S/N prefix 4NN and 6KN. From that I assume your particular machine was not built with that option.
The Group is 8Y-8993 Starting Aid Gp. See attached. I think it ought to be relatively easy to retrofit it, the wiring is all there in the machine harnesses so all you would have to do is plug everything in.
I'll send you a copy of the machine electrical schematic. You might need it.
  • 8Y-8993 Starting Aid Gp.pdf
Zerostart says "core plug in the center of right side" and has a 1,000W and 1,500W. 1,500 watts in a block heater should get it to start right up in ten minutes. The last one I looked up was 600W and went in a "freeze plug" on a 3204 , most block heaters are 400W, so either will work fine. A block heater is my favorite, 30 minutes with 1,000W will make it start like nothing.
512high
new hampshire
Nige and others here is the OP serial number, he PM, I told him to post for others , he is also on a plow forum asking others for help, I said this site was great and everyone here are good people!
Here is the serial # 4NN00278
dzlnut
Cali
Here are the installation instructions for the 124-0687 Heater.
Is the 124-0687 part number the correct version for my engine?
there were some doubts that it was the correct one from the other forum
As far as i can tell, the 0687 is 240V, but one place says 120/240V??? If the element says 240V 1000W and you hook it to 120V, you'll only get 250W. I'd go with 0686 for 1000W at 120V or 85 would be plenty at 750W.
Looks to me like they're interchangeable across both engine families. If yours says 120V, I'd use it.
Here is an extract from the Parts Manual for your specific machine Serial Number.
3T-8724 HEATER GP-JACKET WATER
S/N 4NN1-UP 240-VOLT, 1000-WATT
1 - 4N-8227 - Cord AS-Heater Element(240-VOLT, 15-AMPERE)
2 - 124-0687 - Element AS-Jacket Water Heater(240-VOLT, 1000-WATT)
133-6517 - Cap AS-Dust
132-1448 - Kit-Seal
Are you planning on powering the JWH with 240v or 120v.? It can be supplied with either voltage.
Attached the specifications of 124-0687. As Delmer posted above, if you only supply it with 120v it is rated at 250 watts not 1000 watts.
TBH if the machine was mine I'd be installing an air intake heater not a JWH, espcially considering your geographical location. If anything goes wrong with the JWH installation you are going to be battling coolant leaks for ever. See the attachment in Post #6 for the Parts List.
  • SENR2133-02.pdf
A can of ether is a lot cheaper on those cold mornings.
dzlnut
Cali
thank you everyone for the help I have learned a lot from all of your insight.
I plan on using 120 volt to power up the element
I looked at the element but I do not see any marking on it that says 220 or 120 volt
So it sounds like I should return part # 124-0687 to CAT and get the 120 volt unit
I looked at the Zerostart part # 3500081 Watt: 1500; Volt: 120; it is $150 from O'reillys vs the $300 kit from CAT that I have
Does anyone have the instructions for the intake grid heater?
dzlnut
Cali
How cold are you expecting it to get? and do you have 240 electricity available? The 250 watts will help, especially if you're only talking about 20-30F. plug the same one into 240 and it will warm up in thirty minutes, start fine in ten probably.
dzlnut
Cali
The low temps are generally single digit but it can get into the -1 to -5 range
I do not have 240 power available but the block heater will always be plugged in
