anuradha
Did you check the voltage according to the below process ?
"Governor back up switch at the manual position or when these 2 wires are open in circuit, During acceleration from the speed change dial knob voltage between these 2 wires should be 15 - 30 volts.During deceleration -15-(-30 )
Volts. When starionary 0 V." During this test key switch should be at the on position.
