rcon60
track won't stay tight on cat e110b 9hf01123. Is there a seal or do I have to replace tensioner? Also any instructions please
If you are planning on pulling it apart then you might as well replace everything that could possibly wear while you're in there. You are working with a 30-year old machine when all's said & done.so do I just replace the seal or the rings too and is it simple to do?
I've gotten other parts for it from cat so hopefully there is no problem!You will have to break the track. The idler and adjuster can come out in one piece. Keep in mind that all the E model Cat excavators are Mitsubishi machines and you had better source your parts before you tear the tracks apart. The serial number shows up as good and it's a machine built for the North American Market so your nearest Cat dealer should be able to identify and obtain the parts for it. Don't hold your breath on that though.
