Hello all. does anyone have a service manual on the old Cat D6 serial # 9U machine that would tell how much oil goes in the oil bath air cleaner assembly. if i fill it to what i think are the oil level marks then the air intake pipe is covered by the oil level. when that happens then the air being sucked in by the engine has to actually pass through the oil on it way to engine. i would not think that is the way they should work. Hoping someone out there has better knowledge on these oil bath breathers. thank you.
