Hunter013
I'm going to clean out/ replace the fuel filter housing valves and base. As well as the fuel return directing valve. I'll check the duty cycle of the pedal too.
Is there a certain amount of ATF that should be added to oil? Should the oil be changed shortly after running it with ATF? Would putting any ATF in the fuel system help?
