Just an update on the steering cylinder repair :
Used a 20 ton bottle jack to remove the pins out. Didnt need to flog the lugs with a hammer, they just popped out. Front one took almost all 20 tons of pressure before it popped loose though.
Found out the fuel tank side rod/piston cannot be removed while the cylinder is still pinned. There isn't enough room beside the fuel tank to swing the rod end out far enough to get it past the front half of the loader.
( Must remove the whole ram )
I used the front pin lugs to hold the ram while we removed rod/piston.
Also used the front lugs, the tray of the work vehicle & a peice of cut timber to hold the rod while I broke loose the nut that holds the piston.
Looking at the difference, I think the hydraulic tank side steering cylinder may be able to remain pinned in the machine while it is repaired. There seems more room between the the ram and the hydraulic tank to be able to swing the rod out far enough.
The cylinder is not leaking on that side so wont be rebuilding it yet to find out.
