OzDozer
AISI 1040 is a medium carbon steel containing around 0.40% carbon, and can be heat treated at 844 to 899°C (1550 to 1650°F) followed by quenching in water and tempering.
1040 steel can be tempered at 316 to 705°C (600 to 1300°F) based on the desired strength.
1040 steel can also be satisfactorily flame hardened.
This steel can also be hardened by cold working. Cold working is the plastic deformation of metals below the recrystallization temperature, done with high pressure machinery in the factory.
The tensile strength of 1040 is around 90,000psi, so it rates as a high-tensile steel, but it can be drilled satisfactorily. I'd be using a cobalt alloy drill bit. You'll need an extra long drill, or you'll need to drill from both sides.
The hardened areas will provide major resistance to drilling, although the hardened areas should only be on the outer circumference of the pin.
Encore Metals - 1040-1045
www.encoremetals.com
