Is anyone on line that has access to fault codes for a 924G. I have an active fault code of 081 123 105. The trans ECM was just replaced and flashed 2 days ago. Now I have this code.
MID 081 - CID 1231 - FMI 05
This diagnostic code is associated with the solenoid (brake charging). The FMI 05 means that the ECM has determined that the current of the solenoid is below normal.
The possible causes of this diagnostic code are listed below:
The energize circuit of the solenoid is open.
The return circuit of the solenoid is open.
The solenoid has failed.
The ECM has failed. This is unlikely.
Note: The following test procedure may create other diagnostic codes. Ignore these created diagnostic codes and clear these diagnostic codes when the original diagnostic code has been corrected. Ensure that the diagnostic code of CID 1231 FMI 05 is active before performing this procedure.
Test Step 1. CHECK THE SOLENOID.
Turn the disconnect switch and the key start switch to the ON position. Do not start the engine.
Disconnect the solenoid with the active diagnostic code from the machine harness.
At the machine harness connector for the solenoid, place a jumper wire from contact 1 (wire C881-BU) to contact 2 (wire T799-BR).
Observe the status of the CID 1231 FMI 05.
Expected Result:
The CID 1231 FMI 05 remains active. The FMI has not changed and the "05" is still active.
Results:
YES - The diagnostic code remains active. The jumper wire does not affect the diagnostic code. Proceed to Test Step 2.
NO - The diagnostic is no longer active. The solenoid has failed.
Repair: The solenoid has failed. Repeat this Test Step "CHECK THE SOLENOID" in order to verify the solenoid failure. Replace the solenoid. Verify that the new solenoid corrects the problem.
