Cover gasket 4N0402
Seal in Cover 4C2786
Plates for Detent 6N5482
Spring Under Cover 4N4366
Pin/Detent 4N8179
Spacers(2) 4N0444
Did a little more digging and found some not great pictures.
First one give you an idea of what it will look like with cover off:
#11 are the plates, just below the arrow in picture you can see a small hole and opposite is another this is were the spacer in the parts list are found. Under the shaft you can see the slot the detent pin works in.
Below is anothe not great picture but it shows the shaft out of the gov housing, not something I would suggest right now but might give a better idea of what in in there:
Those parts #6 and #9 are the ones you will hear falling inside if you let the shaft come out!
Hope this helps a little, maybe someone else can add to it. It has been several years since I hand my hands on one of these governors.
