Here is my progress report. All seals went in fairly easily , thanks to all the tips i received here on this forum. The replacement seals barely resembled the ones that came out. The only ones that were identical were the flat split ones. The rest fit but were not identical. The thick one in the middle gave me the most trouble as it was stiff as heck even after warming it up. I finally managed to kind of fold it by squeezing it in the middle and forcing part of it in the groove and then worked the rest in somehow. I was surprised it actually went in. The rest were easy. There is one rubber ring that has to go in a certain way , it was NOT like the one that came out of that slot. Thanks to Nige for the drawing on how it went back and thanks to Swetz for alerting me to the fact that some of them do have a beveled lip that must go a certain way. Otherwise, i would never have seen that bevel.
I had trouble getting the head to slide on the rod. It went on just enough to allow me to attach the piston. Once the piston was attached i shoved the rod into the barrel and it stopped at about 3 to 4 inches in. So i rigged up that come a long system and pressed it the rest of the way in. Reassembled it all, cranked it up and started moving dirt. Hooray.!!
