Rocket Man
Ok, back again. Got the hydraulics problem solved and now the motor keeps dying. It will start up and run maybe 2 minutes sometimes and 15 minutes at the most and then it will scale back like it is going to idle and then just quit.
When it is running it runs good, but does not last long.
Here is what i have done so far:
1) Changed primary and cleaned lines, blew out lines to tank.
2) Changed secondary and blew lines to tank.
3) Operated it on mechanical pump, no change
4) operated it on an electric pump, no change
5) Blew lines out to tank, no change
6) Cleaned filter in the injection pump, no change
7) Looked for and can not find the return line check valve, (do they even have one?)
8) Installed a rubber hose directly into tank thru the filler port to bypass hard line, no change.
9) Put rubber line in 5 gallon can directly and no change.
10) Exhausted all my patience, got mad and kicked tires, no change.
So, if anybody out there has any ideas please let me know so i can try whatever it is i am missing.
