BigWrench55
Yes the injection pump is timed with the engine. If you don’t know how to get the engine time I wouldn’t attempt removing the injection pump. It’s sounds like you are not getting any fuel to the injectors. You have ether a failed shut off solenoid or a bad injection pump. Make sure that you have power and ground to the two wires on the pump. Have a helper turn the key on but not cranking, while you listen and feel at the pump for a click. If you have all of that then pump has failed. Best of luck to you.
