All the bolts are safely accounted for, but the leak is on cylinder #7. My engine guy came down and was listening for a mechanical noise, possibly from the valve train. Some of the other guys said they could hear it. I'm 95% deaf so I couldn't say much. He found the leak by ear, and there is evidence (smut) on a little patch of the head surface adjacent to the manifold, and you can feel the leak "puffing" out if you don't mind getting burned a little. Since it's #7, I'm thinking that it may be possible to removed that elbow section of the manifold and replace that gasket only, but I know there are pins and box ends on that el, so not all too hopeful. Have my doubts.
However, he also noticed an odd issue that seems to be ECM related. There is a erratic miss that seems to move around. It will miss a few times on one cylinder, run smooth for a minute, then another cylinder will miss a few times, then another, then another. The engine guy suggests that we send the ECM to someone with a simulator who can record the injector drive pulses and see if they are inconsistent or just what's going on. We have a diagnostic laptop, but I don't think it will record while monitoring. This is a rapidly fleeting problem and doesn't set a code that we've been able to nail down.
So we have two problems now. One identified, one not. So if I can locate a service center to check out the ECM, we can work on the exhaust leak.
Just a minor update.
