heymccall
345CL PJW00920 6363hours
6329 hrs@ startup, "ENGINE ECM ERROR" in red on screen.
Active errors
36:268-2 programmed parameter fault.
105:590-12 ECM fault.
No Events.
Machine ran normal.
Dealer reflashed ECM.
Machine now normal, and display normal.
6mos later,
6363 hrs@ startup, "ECM FAULT" in red onscreen.
Active errors
36:268-2
105:590-12
Now has logged Event
105:E00179
The first and last occurrences are way outside the current or past meter reading.
AND, now any function that uses pump #1 chatters and shakes whole machine.
Pressure jumps all over the place only on pump #1.
Pump #2 responds normal.
Obviously, the ECM has forgotten its values again, but, what would screw with pump #1 operation?
Machine did sit unused for 4 years, with only an occasional startup.
Active errors
No Events.
Machine ran normal.
6mos later,
Active errors
36:268-2
105:590-12
105:E00179
