Cat 345
Brian Bobb
Saint Lucia
You can check engine speed on monitor in service mode.
Start-Up Of The Service Mode
View Image
Illustration 2 g00662936
Electronic Monitor Panel
(2) Character display
(22) Travel alarm cancel switch
(23) Boom priority mode switch
(24) Swing priority mode switch
(25) Fine control mode switch
(26) User mode switch
Note: The engine can be running or the engine can be stopped, when the "Service Mode" is started. When the engine is stopped, the starter switch must be in the ON position. You should know the procedure to start up the "Service Mode" in advance.
  1. The following switches should be depressed and held for 2 seconds or more simultaneously: travel alarm cancel switch (22), fine control mode switch (25) and user mode switch (26) .
  1. The time display and the dial display on the character display (2) will change to a "0" and a "0". The left character position will flash.
  1. You need to enter the following security code: OE 32 3A.
    Note: The security code must be entered within 10 seconds after the first procedure (1). Otherwise, the time display will return. You should learn the procedure of entering the security code in advance.
  1. The procedure to input information is listed:
    1. The figure that is blinking on the character display (2) can be changed. In order to change the figure, you should depress the boom priority mode switch (23) or the swing priority mode switch (24).
      • The figure that is blinking increases (Boom priority mode switch (23) )
      • The figure that is blinking decreases (Swing priority mode switch (24) )
      The character position that is blinking can be shifted by depressing the fine control mode switch (25) or the user mode switch (26).
      • The character position that is blinking shifts to the right (Fine control mode switch (25) ).
      • The character position that is blinking shifts to the left (User mode switch (26) ).
  1. After you enter the security code, the service mode is activated by depressing and holding the following switches for 2 seconds or greater: travel alarm cancel switch (22), fine control mode switch (25) and user mode switch (26). The service mode is automatically activated 10 seconds after the security code is entered.
  1. Now, the "Service Mode" is activated and the character display (2) will display "10" on the left two character positions and "1" on the right character position.
Note: Refer to the chart of Service Codes for selecting the functions for the "Service Mode".
Changing The Service Mode
  1. The boom priority mode switch (23) or the swing priority mode switch (24) is pressed in order to change the figures that are blinking on character display (2) .
  1. The position that is blinking on the character display (2) can be shifted by depressing the fine control mode switch (25) and user mode switch (26) .
    • The position that is blinking shifts to the right (Fine control mode switch (25) )
    • The position that is blinking shifts to the left (Swing priority mode switch (24) )
Table 1
Service Code Function
10 Automatic Travel Speed Change
11 Low Temperature Control
12 Engine Speed
13 Engine Coolant Temperature
14 Hydraulic Oil Temperature
16 Digital Input
17 Software Version
18 Real Time Error Code
19 Error Log
1a Check For The Engine Speed Dial
1b Name of Model and Type Of Engine
1c Real Time Error Code (ATT)
1d Error Log (ATT)
20 Command Signal For The Power Shift Pressure
21 Displays Higher Delivery Pressure Of The Main Pumps
60 Proportional Reducing Valve Sweep Test
62 ON/OFF Test Of Digital Output
66 Fixed Power Shift Pressure
67 Engine Speed Change
7d Fan Speed Calibration
6c Fan Speed Sweep Test
71 Proportional Reducing Valve Calibration
80 Setting Of Hydraulic Oil Type Mineral Or Biological
81 Setting Of AEC Speed
82 Setting Of AEC Delay Time
83 Setting Of Memory Mode
84 Setting Of Reduced Horsepower For Attachment Pump
85 Setting Of Engine Speed For Low Idle Switch
86 Setting Of Pump Quantity For Hammer Mode
87 Setting Of The Hammer Circuit Pressure
88 Setting Of Pump Flow For Hammer Mode
8a Setting Of Power Offset For Attachment Pump
8b Change Of Preset Conditions Of Main Pump Output
8c Change Of Upper Limits Of Preset Conditions Of Main Pump Output (Such As Power Mode Or Engine Speed At Dial Position 10)
Thank you so much. I will try this tomorrow.
Brian Bobb
Saint Lucia
Mr. Hystat put this together a while back. It shows you how to get into the service mode in a B model excavator.
He also has one on the throttle control backup system.
Thank you so much for these videos. I will follow them tomorrow and see what happens.
Mobiltech
Sask.
Which engine speed sensor did you replace ? There is one in the flywheel that the hydraulic ecm uses. That one has to have clearance set.
Brian Bobb
Saint Lucia
The one on the flywheel. A guy screwed it in fully and then backed it out a bit. What is the clearance for it?
Mobiltech
Sask.
If he backed it out 3/4 turn would be ok. You can view the output on the monitor in service mode.
rmllarue91
northeast pa
field technician
Switches on arm rest one puts it in bypass you have to work other the Rev it up each flip is 50 or 100 rpm
Oxbow
The 345 was built as both B & C models John. C-model production appears to have ended somewhere around 2007-2008.
SIS also lists a 345D model but it appears to have been a Japan-only machine, which of course could always end up somewhere else in the world as a grey market import.
I have a 345DL, in the states.
RAJ 00252. I haven't looked to see where it was made.
Oxbow
It's strange, there is no information on the 345D in the resources I look at. The engine for RAJ00252 was built in Mossville so it stands to reason that the excavator would have come out of the Cat Aurora Plant.
Interesting indeed. I use the customer (free) version of SIS and have looked up parts for it numerous times. Your resources are surely far more comprehensive than what I use.
SIS gives the date of manufacture and the date of shipment of a particular machine, but not the build location.
One of my other sources is engine details which is how I came up with the fact the engine was built in the Mossville plant. The Wheel Loader & Excavator assembly plant is at Aurora which is literally just down the road.
The weird thing for me is that IronRecord contains no information whatsoever regarding the 345D.
I finally woke up and thought about how to check this and opened my serial number program which lists the point of origin for each serial number. 345D machines were made in Japan, Belgium and the United States. Prefixes for US made machines are EEH, MLK, and YEE. The only Belgium serial number shows as KFH. All the rest were made in Japan.
Oxbow
My machine is a 345DL VG. As Nige mentioned I do no see any origin through SIS, so out of curiosity I went back to my Performance Handbook #39 and looked it up. It shows the 345DL with fixed gauge as Japan and U.S. sourced. 345DL with variable gauge is U.S. sourced @ 108,610lbs., and Belgium sourced at 115,167 lbs.
None of this matters, just satisfying my curiosity.
Cmark
Look on the serial number tag on the RH base of the cab. It tells the country of manufacture.
Jeremy Whittaker
Mesa, AZ
I'm looking at purchasing one of these 345 BL and the throttle won't work as well as the display not turning on. The guy says sometimes it will turn on and then the throttle works fine. From what I'm reading on this forum it seems like this manual switch may have been activated or simply gone bad which would cause both of these issues. Is that a safe assumption? I've never bought one of these before and I'm just a bit nervous that I might be buying something that is going to cost me thousands more to fix. Appreciate any advice! Thanks!
