They say don't weld on the machine with the controller connected. I think the starter commutator frying damaged the controller.
Tracing and checking wiring from both directions to the Cat Controller leads to an electrical fault there. All wires, switches, connections and relays either side of it checked out.
I need a new controller, or a by-pass...
I have a partial copy of senr9291, from the dealer.
Bear with me here in a minute as I try to figure out how to get proper voltage / amperage to the proportional reducing solenoid valve
(PRV).
"a decrease in engine speed increases the signal current to solenoid which increases the magnetic force... The powershift pressure increases and the pump detrokes".
Then conversely, they say
"an increase in engine speed decreases the signal current to selenoid which decreases the magnetic force... The powershift pressure decreases and the pump upsrokes.
What's the correct voltage and amperage to the PRV from the ECM for an 'upstroke'?
24 volts at battery amperage is too much for the prv and it will not upstroke, i tried it.
Maybe I could go to the dealer and they would let me put my clamp meter on a solenoid on a similar machine?
The dealer couldn't tell me what voltage and amperage should be.
