petepilot
get no arguement out out of me but i did run into one 1150 years ago never seen anotherAn "in-line" 3208 pump?? no such animal..??
The 3208 inj. pump is a "V".. just like a small V-8 engine..
Not gaining from a 6V-92T ? Really? Check the available HP and torque ratings. Makes that "turboed" Cat look like a joke. And I've driven a few 6V-92T's, made NA 8V-71's look weak.That could be an interesting way to go.. nudge nudge wink wink
has the standard v pump too
Dont quote me, but from pics Ive seen the intake is the same, the turbo version has a cast piece that bolts in place, replacing the current part that connects direct to the air cleaner
ok having sat down and done the math, it would be a gain of 19.4% ish still better then not having it, and certainly better then a poke in the eye.
The thing already gets warm on long hills, like any motor will, just have to watch your revs and keep it in a gear that can gain speed without mashing the throttle wide open and it will be fine,
Also there are several issues with swapping literally any other diesel engine in, 1, RPM range 2, will it fit 3, can I afford the swap 4, finding one that runs, and fits
8.3 cummins sounds like a good motor, and I like cummins, but any around are going to be far more expensive then they are really worth 10-20k
any 6v detroit is a pipe dream around here, and not gaining anything anyway
8v detroits are cheap, but probably wont fit esp 8v92s
everything else is wishfull thinking
So back to plan a, turbo it or run it until I can afford something better
not positive but i think most are factory drilled whether turbo is used or not
View attachment 184808 View attachment 184809 View attachment 184810 View attachment 184809 View attachment 184810 (not a sales pitch) heres the set up . as far as i know this is the only way a turbo will fit, plus manifolds and connector pipes, block must be drilled for the oil supply into the bottom of the turbo, not positive but i think most are factory drilled whether turbo is used or not
6V-71 minus turbo is 238 HP with a lot more torque than the cat, turbo 6V-71 can hit 300+ HP.worst case, I can manage drilling a hole or two, but the compressor has oil supplied as well, so a guy could just T into it if need be
Think I may have meant 6v71, but got distracted by something shiny, the 6v71 only runs like 235hp or sumsuch
a 6v92 would certainly do the trick, if a guy could find one
In the early 80's I ran a GMC 9500 with a 318 8V-71 hauling grain from central Washington state to the river ports in Pasco, James (the GMC) needed some transmission work so I broke out "protection power" for 3 days. It was a 1971 Chevy C65 with a 427 and a 5 and 2. Air brakes and a 5th wheel. Oh, a rubber band tandem too.I would say diesel vs gas might be an exaggeration, I drove some of the same trucks with 8.2 Detroit/427 gas or 3208/534 gas and the gas engines made you want to get out and push sometimes.
