BrianGrenier
Hi Experts,
Could I get an opinion on this picture?
On this 9JS00308 Cat 320 BL 138 FWHP, the Swing Gear and Bearing seems to "catch" and the structure will not swing after working in some positions, especially after working at a diagonal to the tracks and shaking the machine can get it to swing again.
I searched the forums and saw helpful posts,@John C. had a good video on one machine.
The attached picture is an inspection plate to the swing gear.
The manual states to "Add 5P-0960 Multipurpose Grease to the swing gear and bearing after it has been installed. Refer to the "Operation & Maintenance Manual" for lubricating the swing gear and bearing at specific service intervals." I was not able to locate the section specified above.
A Cat maintenance video said several gallons of swing gear grease should be in that well. I may be mistaken.
So, what can you see with the picture? What grease and quantity should be in that well?
