dirtdobber1
Hello all. I have a Cat 312 B L with about 3,000 hours. The machine has been sitting idle for a month or two. I just repaired a hydraulic leak and started the machine to discover that the electronic engine speed control will not bring it above idle. There are two pieces of history that are important.
First, and most importantly, while the machine was idle some rodents chewed on the wiring harness. I have repaired the obvious damage, but mice can get into more places than I. I recognize damaged wiring is the most probable cause of my troubles.
Second, the hydraulic leak completely drained the system. While the machine was down, I switched off the main power supply at the electrical panel behind the cab (to keep some dummy from trying to operate it).
To give you some symptoms, the engine speed control knob and the digital display are communicating. As the knob is turned, the numerical readout changes accordingly. The controller (located in the same compartment as the hydraulic pump) is functional because it works enough to allow the engine to start and idle (it has to move the rack on the injection pump to start). The cableling from the controller to the injection pump is fine.
In light of the fact I likely have a wire chewed up somwhere, I guess my question is this: Since the hydraulics were drained and the main electrical shut off, is there anything that has to be reset for all to function properly?
Thanks in advance for your thoughts.
