Slow response time on all functions, noisy pump. Pump rattles and groans. Hyd filter is new, old one was cut apart for metal flakes but found none. Do not have
high pressure test equipment readily available but were nominal on tested circuits. Everything seems to indicate bad pump but want to make relatively sure as it will not be easy nor cheap to replace.
