Aaron.ampcon
I cant see but didnt feel any with my finger just oil pouring outCan you see weather springs are behind this vave,
It looks like that valve buts against the piston, and on the other side of the piston there’s two springs that push against the seat which connected to the pin, and that pin is the one that pushes on swash plate.I cant see but didnt feel any with my finger just oil pouring out
Thinking to buy new valve and install. Bypassing this step of the diagnosis for now what do you think I should look at next?It looks like that valve buts against the piston, and on the other side of the piston there’s two springs that push against the seat which connected to the pin, and that pin is the one that pushes on swash plate.
I wouldn’t buy that valve unless I see damage to it and know for sure that’s a problem.Thinking to buy new valve and install. Bypassing this step of the diagnosis for now what do you think I should look at next?
So I've been doing some research and I believe these springs are the ones you mentioned but they are located inside the pump to get to them. So I think I'm gonna pull the pump to check coupler.I wouldn’t buy that valve unless I see damage to it and know for sure that’s a problem.
Next is basically your choice, coupler or isolate the pump and pressure test it.
As far as I understood from the previous posts that your problem is low pressure.
So it is either pump or main control valve.
I would test the pump first.
Usually internal springs neutral pump. Broken springs would give u pump out pit my experience leads me to believe you have issue with load sense pressure or the regulator is not working
So how do I go about troubleshooting load sense or regulator issue?Usually internal springs neutral pump. Broken springs would give u pump out pit my experience leads me to believe you have issue with load sense pressure or the regulator is not working
Have not took apart pump yet what do you suggest?As I admitted before - I never worked on E series of these machines, but: the only pumps that servo piston springs are return to neutral is the closed loop or hydrostatic pumps! And this is definitely not the case!!!
So here is the question: do you for certain know that this is LS pump ( then those springs are bias springs, but still not returning to neutral), or that is what they call a mini excavator duplex pump?!
I only can say what I would do.Have not took apart pump yet what do you suggest?
I would open and inspect and get back to you with what I seeI only can say what I would do.
I would open up and inspect, but you have to decide on your own.
Pump looks fine internally no unusual wear no broken componentsI only can say what I would do.
No problem I would have to take the pictures when I'm back at the machine but there were no major or deep digs or scratches if that's what your looking for. Saw some wear on swash plate bearing which I dont think would cause the problems I'm having.Well! It is not duplex pump.
There’s some contamination scratches on the piston slippers. If you can, please post the picture of the piston block where the valve plate rides against, and also wipe the valve plate off and take a picture again, please.
