Cat 299d2 3516-18 ACU Catalyst Reagent Concentration Low
.....perhaps it was a hate crime, but we got a machine that the def tank was completely full of hydraulic oil. looked liked the Chinese egg drop soup :eek:
Most likely whoever filled up the tank had no idea what it was for and didn't bother to find out or ask before tipping hydraulic oil into it.
I once had a service truck add multipurpose grease to the hydraulic tank on a big shovel, and someone added MPG to the bulk coolant tank on a service truck. Both were easily fixed long-term by making changes to the quick couplers so that it became harder (note I did not say impossible.!) to add the wrong fluid to a compartment.
In my experience trying to make things idiot-proof only permits Darwin to develop a better class of idiot.
BigWrench55
Somewhere
The 769C truck had a tank next to the cab for the steering system. I was still a newbie and was getting a euclid truck of similar size ready. It had a tank next to the cab also. Only this tank was for coolant and I added 10 gallons of hydraulic oil before I realized my mistake. lots of cascade and 5 hours later I had the coolant flushed of oil.
92U 3406
Western Canuckistan
Wrench Bender
CAT calls it a DEF manifold. And yes they are prone to fail, but it is covered under the emissions warranty, but they are cat backorderd.
Are you sure? I've worked for Cat for a few years and always seen it refered to as a PETU in their literature. Unless they just call it that on their bigger equipment and a DEF manifold on the smaller stuff.
big ben
Vancouver Island
This is what CAT is claiming to be the problem, in case y'all are interested to know.
You appear to work for the dealer and therefore should know enough to not start posting internal OEM to dealer communications on a open forum. It’s one thing to help or nudge people in the right direction with some good advise and another to post attachments like that. Dealer/OEM employees are in those positions as they should be able to hold themselves to a higher standard and conduct themselves in a professional way - at work and when posting on a forum.
But hey what do I know
LEGO
Texas
Diesel tech
Yes its possible, I work in the compact construction equipment department, so maybe CAT does call it something else for the bigger equipment.
LEGO
Texas
Diesel tech
I've got to tell you Nige, I'm learning a lot from reading your comments on these forums, thank you.
Diego I.
Bolivia
[QUOTE = "LEGO, publicación: 952407, miembro: 96313"] Que problema tiene la maquina? o que codigos aparecen en la pantalla? [/ QUOTE]
Estimado Lego
adjunto lo solicitado y quedaré atento a los comentarios.
LEGO
Texas
Diesel tech
Estimado Lego
Diego, lo primero que hay que revisar es la calidad de el liquido DEF, para eso hay que levantar la cabina y sacar dos muestras, una directamente del tanque de el def, y se puede desconectar la mangea pequena en el tanque para sacar la muestra y la otra directamente de el modulo de def, que tiene el filtro del DEF, y para eso se necesita un refractrometro de DEF. La calidad deberia estar al 32.5%. O muy cerca de, hasta 34%. Si no esta en este nivel, tu DEF esta contaminado y hay que remplazar el liquido. Pero este es el primer paso. Dejame saber el resultado.
Diego I.
Bolivia
Estimado Lego:
Ya hicimos todas estas acciones y todo apunta a la necesidad de cambiar el sensor (manifold DEF).
Sin embargo, tomando en cuenta que la calidad del diesel en Bolivia es muy mala y solo es posible la operacion de motores hasta TIER2, el motor de la miniexcavadora es TIER4.
Que podríamos hacer al respecto?
De antemano quedo agradecido por la gran cooperación.
Saludos cordiales.
