I've searched everywhere and can't find the information I need. You can skip story and go to the next paragraph if you don't care how it happened. I'm in the middle of installing the drain tile system around my wife's new building. I've prepped two sides, and started putting in the washed rock and pvc. I was gently dropping in washed rock to cover the pvc with the skid today and it started making a periodic squeaking, such as a rock hitting a rotating bolt when moving. Then with a full bucket, I turned to start dumping and I was stuck. The RH track wouldn't move. Figured there was a rock stuck, even though I looked it over 5 minutes before because of the squeak. Didn't find anything, but took a few minutes to clean out around the cage just in case. Had my 9 yo son get in and try to move it so I could see what was going on. At first I thought it was something on one of the end idlers catching a bolt, but after a bit more movement, I noticed it was not at the correct period, and it would stop the cage first and the track would slip a little over the cage. After a little thought I figured out it was the park brake not releasing on the RH side only, not something stopping the track.
The electronic portion of the park brake seems to be working properly. The LH track releases and moves freely. The RH only moves a couple inches. Released and applied I can feel and hear fluid movement in the small set of lines going to the drive motor. While on the LH side there is no evident fluid movement. My conclusion is that the seal inside the park brake piston has failed.
If the system is one application solenoid and T'd to the two separate park brake pistons, then it would need to be either a hose flow problem (damaged) which is unlikely, or internal to the park brake actuator/piston or whatever it is inside the drive motor that locks it. Now I can't find any actual information, so I can't confirm that. I can't even seem to find a parts diagram from Cat right now, which I thought I use to be able to access. I've had this 277B for 5 years now.
Here's my questions. Can anyone confirm that there is only one park brake solenoid, or that the lines are T'd from the control out to the drive motors instead of individual lines out? Does anyone know if the park brake portion is serviceable at all? Can it be disassembled and resealed, can you get seals for it?
I am/was a med/heavy truck tech. My specialties were electronics/computer controls and component rebuild. I would much rather rebuild an engine, than to remove it from the vehicle, but I've done both many times. I have no fear of disassembling a drive motor if I have the special tools to do so.
