CAT 259D3 Fuel Issue
Hunter013
Wisconsin
Head Floor Sweeper
S/N: CW924630
Machine bogs down after running for awhile. Sometimes after you dig into a pile or if you just sit at high idle, it'll bog down. I sent it to CAT because it still had warranty. They did a fuel pump calibration and couldn't recreate the issue so they said it was good. We ran it for 1-2 weeks with no issue. Then it did the exact same thing. Sent it back to Cat and they ran it off a separate fuel supply and said there must be something in the tank. We drained the fuel, stuck a camera in there and couldn't see anything obvious. I drilled more holes in the pickup tube thinking it might be something bigger covering the hole. We ran it and it had the same issue. One of my mechanics took the rubber line off the intake side of the fuel filter and blew air back into the tank. He heard a pop and it ran fine for a week or so. Came back in again with the same issue so I did the same thing as my mechanic. This time I pulled out the pickup tube and covered it with a rag and shot air in the line hoping to catch whatever might be in there with no luck.
What else should we check?
ahart
Indiana
We have several CW9 machines and many of them have had the same symptoms. I’ve managed to collect the large chunk of rubber that is plugging the suction line coming from the tank. I haven’t figured out where it comes from. Usually once I get it out, the problem doesn’t return.
ahart
Indiana
Not much serviceable on this pump assembly, PN: 630-7959 If the pickup tube and line going to filter are clean then whatever you blew back into the tank is blocking the flow at random.
heymccall
Western Pennsylvania
Cat doesn't sell the pump separately on the filter head. It's a Stanadyne, and available aftermarket.....but, you just need to disassemble what you have and clean the inlet elbow and the pocket that the pump sits in, along with the outer concentric stem that goes in the center of the filter.
Hunter013
Wisconsin
Head Floor Sweeper
I had one of my guys dissassemble the filter head and he said there was very minimal debris in there. Nothing he thought that would affect anything. He doubled checked the tank and lines and put it all back together. Hopefully in a few days I can get someone to test run the machine and get a concrete answer.
Hunter013
Wisconsin
Head Floor Sweeper
Did he remove all the fittings from the head and check them, or at least blow through them with compressed air.?
All fittings were removed and had air blown through.
He put it back together and it ran fine for a day or two, then the bogged down again. My next thought is to somehow check voltage at the pump while it bogs down to rule out the electrical side of it.
Hunter013
Wisconsin
Head Floor Sweeper
Did anyone ever drain the water/cr@p from the tank.?
We have at least twice now. Stuck a camera in there and could not find anything. We even flushed it with fresh fuel and no contaminants came out.
Hunter013
Wisconsin
Head Floor Sweeper
Sent it back to Cat and they are saying something has to be in the tank. Need to remove the engine to be able to take the fuel tank out. I'm getting a quote from them for it. Has anyone had to do this before?
ahart
Indiana
I’m thinking I ended up getting 3 fat chunks of rubber out of the 259D3 before it finally quit doing it. Haven’t been to it for that issue in over a year now.
Simon C
Heavy Equipment Mechanic
If something in the tank is blocking randomly, a vacuum gauge teed into the line from tank to fuel filter would show it instantly.
Does the top of that tank afford a guy the ability to put a plastic pipe down to the bottom and corners with the pipe hooked up to a 20 liter suck pail that is clean for a vacuum. Would not have to suck too much out to get dirt from bottom that is hiding. You can even blow some air into the bottom as you twirl the pipe to loosen any chunk that might be in a corner.
Wouldn't take too long and easier than tank out.
Simon C
ThreeCW
near Calgary, Alberta
It sounds like a restriction in the fuel system is hiding somewhere, now just to find it.
Building off of SimonC's idea, using a vacuum gauge tee'd into a hose going into an air operated fluid evacuator, you could suck fluid out at several points along the low pressure fuel supply system to see if you can identify where the restriction is occurring.
A bit of a science experiment, but if it works, it would save an engine pull.
ThreeCW
ahart,
What size was the "large chunk of rubber" that you found in your CW9 machines?
