Hunter013
S/N: CW924630
Machine bogs down after running for awhile. Sometimes after you dig into a pile or if you just sit at high idle, it'll bog down. I sent it to CAT because it still had warranty. They did a fuel pump calibration and couldn't recreate the issue so they said it was good. We ran it for 1-2 weeks with no issue. Then it did the exact same thing. Sent it back to Cat and they ran it off a separate fuel supply and said there must be something in the tank. We drained the fuel, stuck a camera in there and couldn't see anything obvious. I drilled more holes in the pickup tube thinking it might be something bigger covering the hole. We ran it and it had the same issue. One of my mechanics took the rubber line off the intake side of the fuel filter and blew air back into the tank. He heard a pop and it ran fine for a week or so. Came back in again with the same issue so I did the same thing as my mechanic. This time I pulled out the pickup tube and covered it with a rag and shot air in the line hoping to catch whatever might be in there with no luck.
What else should we check?
