ThreeCW
Below is a picture of the screen after draining with only 50/50 blend fresh from the station with no additives. You can see some waxing but not nearly as bad. Machine ran for 30 minutes with no issue -- it was about 8 below F. Now I'm not sure if I should add the Hot Shots Secret that I ran all last winter without issue or switch additives -- maybe to Power Service White Bottle. It'll be -15F here in the morning with windchills hitting -30 to 40 the next couple days.
If the "50/50 blend fresh from the station with no additives" is still waxing up on you, then that "winter" fuel is not blended for the low temperatures you are experiencing. A properly blended winter fuel should not be waxing up on you (causing filter plugging) and you should not "have to" add an additive to achieve low temperature operability ... additives that provide cold weather protection can be used to provide "additional" protection, but the winter diesel fuel must be properly formulated (blended) to meet your low temperature requirements.
I suggest talking to your fuel supplier and find out the temperature rating of the diesel you are buying. Based on your waxing problems, it appears that the fuel your are buying does not meet your low temperature requirements. One of the reasons for out of spec fuel can be if it is old inventory ... blended for September or October temperatures ... which will not work for you in December ... even with the addition of a fuel additive.
Your best option would be to find an alternate fuel supplier with diesel fuel that is correctly blended to meet the low temperatures you are seeing today and the low temperatures you expect to see the rest of the winter.
As an example, I have attached a chart for Alberta diesel fuel showing the seasonal operating temperatures. You may be able to find a similar chart for your region. It is a handy chart to have for deciding on when to purchase your winter fuel requirements.
