Dgreen4298
i have a cat 215 with a 3304 engine that has low power under load. Starts right up and runs great until you put it under load then it bogs down and will kill the engine if you don't let up. Doesn't mater if you are digging or traveling. Changed the fuel filter and strainer. Fuel primer pump seems to not do anything when pumped, it was hard to prime the system after changing filters. Have not replace the feed hoses from the tank because I really don't think that is the problem.
