Cat 1973 815 Hydraulic Issues
Hunter013
Wisconsin
Head Floor Sweeper
Cat 815 S/N: 91P00572
Machine won’t turn and blade won’t move. Drives forward and back just fine. Hydraulic oil is overfilled, I can see it at the bottom of the filler neck.
I don’t know where to start troubleshooting or testing pressures. Any advice is appreciated. Thank you.
What's the background.? Did the steering/implements simply quit suddenly or were they getting worse over time unilt they quit.?
The two systems use a common 2-section pump, so maybe that would be the first place to start looking. If the loss of function happened suddenly could be a broken pump shaft.? Attached are a few docs that might be useful.
  • Strg & Impl SysOp.pdf
  • Strg & Impl T&A.pdf
Hunter013
Wisconsin
Head Floor Sweeper
Operator was going along fine, then suddenly lost all blade and steering operation. I'll look at these documents and check out the 2-section pump to start with. Thank you
